The pre-determined intonation compensation ridge is calculated for string sets in the range 009-042 to 010-052. Any heavier than that and you probably need a different ridge shape.
hmm, I've been on 11-52 for a while on my s2 24, would consider going heavier, probably not lighter.
Sounds like a new bridge would be neaded.
The guitar itself is already more than I told myself I could spend, so not really able to chuck more money into hardware L/
Cheers for the responses !
I tune to drop B and the adjustable is necessary at that point (I use 11-64).
At C with a 52 it'd probably be usable but not ideal. YMMV
Hopefully the bridge end to end grub screws will intonate it to a good enough standard across the board.
For me, my guitar or intonation can be out by a few marks, I wouldnt be able to hear it though. Crappy ears though haha..
The chops are tight and the technique and tuning is spot on.
