FS Samson Servo 240 power amp and Behringer Ultra Curve 8024 static graphiliser!
Not sure if this should go in miscellaneous as its PA rather than guitar-based?
Samson Servo 240 power amp - 120w per channel, ideal for studio setup or small PA (or for a very 'hi-fi' guitar preamp setup). Good used condition, with a couple of scratches on the front panel and some scratches and sticker residue on the top. A well built unit with a massive heatsink. Looking for £60.
Behringer Ultra Curve 8024 - 31 band stereo graphic, feedback destroyer and real time analyser (ooh, er!). Basically a flash graphic eq with nice display rather than faders. Lots of uses - main PA, monitor mixes, 'brickwall' limiter to protect your speakers, noisegate etc etc.
Has some nasty scratches on the top from a reverb unit that didn't have rubber feet! For some reason the back left screw on the reverb was sharp so whenever it was moved (carelessly I may add) it scratched the Behringer. Other than that, normal signs of wear. Looking for £60.
Not sure about postage - the Behringer is quite light but the Samson is a weighty beast (always reassuring for a power amp!). Will explore if there is any interest and charge at cost. Otherwise, collection from Bristol would be the preferred option.
