2012 Martin D-41 Dreadnought
Due to me venturing into setting up my own guitar workshop and business, I need to purchase some needed machines, so with reluctance I am putting up for sale my D-41 along with some other bits as well.
I bought this new from GuitarGuitar in Birmingham in 2012 so its 5 years old. I am based in Northampton and available most evenings from 7pm onwards you more than welcome to play this beautiful guitar before you purchase. Below is the blurb from Martin. With regards to electrics I have had fitted a LR Baggs Lyric microphone pick up which cost me £250 at the time although I believe they have gone down a little.
The Tone on this is truly stunning and even when I tried high end Taylors and Gibson this still knocks them out although I understand its preference.
String wise I am using Ernie ball Aluminium Bronze 11 -52 and this adds (I think to the low end a little) and a fresh set of these will be included in the sale ( I can restring if you want)
If you want to buy these new Coda music have one for sale at £4,150! so mine is a snip plus you have the added bonus of the wood mellowing out ( I thought it was a myth but its not)
Never been Gigged, only had home use and is a bit of wall art at the moment.
Price £2,650 sorry no trades price is flexible, so try me
Model: D-41
Construction: Dovetail Neck Joint
Body Size: D-14 Fret
Top Material: Sitka Spruce
Rosette: Abalone with Multi-Stripe
Bracing Pattern: X Brace
Brace Shape: Scalloped
Brace Material: Sitka Spruce
Brace Size: 5/16"
Back Material: East Indian Rosewood
Back Purfling/Strip: Style 45
Side Material: East Indian Rosewood
Endpiece: White
Endpiece Inlay: Multi-Stripe
Binding: White
Top Inlay Material: Abalone with Multi-Stripe
Side Inlay Material: N/A
Back Inlay Material: Multi-Stripe
Neck Material: Genuine Mahogany
Neck Shape: Low Profile
Neck Taper:Standard Taper
Plek: Yes
Nut Material: Bone
Headstock Shape: Solid with Square Taper and Diamond
Headplate Material: East Indian Rosewood
Headplate Logo Style: Block Inlay
Headplate Binding Material: White with Multi-Stripe
Heelcap: White
Fingerboard Material: Ebony
Scale Length: 25.4"
Neck Joins Body At: 14th Fret
Number of Frets Total: 20
Fingerboard Width at Nut: 1 11/16''
Fingerboard Width at 12th Fret: 2 1/8''
Fingerboard Inlay Material: Abalone
Fingerboard Inlay Style: Reduced Hexagon
Fingerboard Binding Material: White
Side Dots: Black
Back and Side Finish: Gloss
Back and Sides Color: N/A
Finish Top: Gloss
Top Color: Clear
Finish Neck: Satin
Neck Color: Dark Mahogany
Bridge Material: Ebony
Bridge Style: Belly - Drop in Saddle
Bridge String Spacing: 2 1/8''
Saddle: Compensated Bone
Saddle Radius: 16"
Tuning Machines: Gold Enclosed Gear
Bridge Pin Material: White Plastic
Bridge Pin Dots: Abalone
Pickguard: Faux Tortoise
Case: Molded Hardshell
http://i.imgur.com/Z9gKx68.jpg
http://i.imgur.com/7IJE0dH.jpg
http://i.imgur.com/Y0faCGr.jpg
http://i.imgur.com/pXnNIn8.jpg
