Funny thing is the delay through the front of the amp didn't make the tone brighter when engaged I only noticed it through the loop.
I put a TC Bonafide buffer in front of the Flashback and a HOF through the loop and the issue kind of went away, the tone was a little brighter with the pedals in the loop regardless of whether they were switched on or not, so at least it was constant and no tone change when switching the pedals on or off, but the tone with the effects in the loop was definitely different to the tone with no effects at all.
What loop is in the 2204 - Marshall, Tube Town or some other?
@ICBM the reverb is a HOF mini and the CC is before it. It's the Ceriatone 2204 HW.
I suspect it is a poor buffering issue of some sort, probably the amp. You might need to buffer the loop externally, if you don't want to replace the pedals with buffered ones.
No, unfortunately does not! I have been considering upgrading to the full fat HOF for a while though...
