Were you using the same plug gang for FX and both amps?
Were you using a phase invertor and groundlift box?
Were you using any extention leads to the mains supplied from the venue?
Yes using a phase/ground lift box. However I didn't flick any switches to be honest. Always worked fine wherever I've used the amps before at other venues using the box
No used my own extension leads
Those are the top 3 causes.
The only other possibility is you were gigging at @Wazmeister gaffe?
Bandcamp
Spotify, Apple et al
