thomann unloaded wide 1x12 (21.5"wide and 12kg) but then for £2 more they do this one loaded with a v30! thomann v30 cab (18.5" wide and 14kg)
They both look silly cheap to me but it depends if you need something even lighter...
Are Purple Chilli still going? They were the lightweight cab specialists.
Casters definitely plus rack holder, plus socketing plus storage. This will be an UberKab.
edit: the Jr Cab is too small for the Stiletto to sit on, even on its side.
Looks like Jet City or Montage so far. There's a Montage in a local shop, so I might have a look there.
8ohm, 80w, 102db. £160 firm. Just thought I'd put that out there
The Montage wasn't wide enough to sit the Stiletto on. Very pleased with the Blackstar, though it's 16 ohms and the amp output is 8.
Safe mismatch acc to Mesa Boogie manual, and sounds great.
It's also surprisingly light and the colouring matches nicely.
