PRS...DGT or 594?
JonHoskerJonHosker Frets: 398
Advice sought for an easy access neck double humbucker vintage type 6 string...
Weight to consider (guitar' s I mean) Trem useful too. Testing them is tricky as a big drive.
Thanks jon
  • guitars4youguitars4you Frets: 14750
    the fact that you said trem has almost created your own answer - DGT then - both capture the more vintage side of life - both are great guitars but the trem avenue seals it IMO
  • mynamesnotbobmynamesnotbob Frets: 114
    edited October 2017
    I bought the 594, I had an afternoon with a room full of 594's and a couple of DGT's and came away with my favourite one. It was the neck carve on the 594 that one it for me, and the tapped sounds - after that it was just the one that worked best for me. And as always the one that I went in with my heart set on, was not the one I walked away with.
    If you want a trem the DGT wins by default
    Weight will be about the same for both and vary more guitar to guitar
  • crunchmancrunchman Frets: 11517
    If trem is important then DGT as @guitars4you said.
    If you do want something that can get close to a Les Paul then the 594.  The DGT is a great guitar but the trem does give it a slightly different vibe.  I ended up selling the one in my avatar.
    The best thing to do is have a day out and go to a big PRS dealer and try both.
  • If you're in Chester (looked at your profile) get to Sounds Effect Premier in ormskirk, and play away to your hearts content, it'll take less than an hour to get there
  • SchnozzSchnozz Frets: 2036
    edited October 2017
    I had a PRS SC58 and it was just way overpriced, but flawless and not so Les Paul sounding, so I went back to a Yamaha SG (3rd of the price).
  • JonHoskerJonHosker Frets: 398
    Thanks for the comments.
    Testing out day in the planning stage!
    Jon
    endorse that - best selection for new PRS Guitars in NW area
  • TwinfanTwinfan Frets: 1625
    Yep, another vote to go and see Tim and Andy at Ormskirk.  Great selection there but ring beforehand to check they've got a DGT in stock.  They always have 594s but not so many DGTs for some reason.
