It is actually quite difficult to damage any 1/2 decent valve amp with a load box. The main thing is you MUST own a test meter and once you have built the thing do 'cold' check for resistances. So long as the load on the amp is around 50% of the setting ON the amp you will be ok.
Dave.
@clarkefan - what impedance is the load? If it's 16 ohms, no problem. If it's 8 ohms, don't crank the amp through it unless you've had the switch in the 16-ohm jack bridged - the current to the 8/4-ohm jacks goes through it. This contact point is a cause of blown output transformers on these amps.
It's also worth checking the screen resistors and making sure the points of their standoff legs are well clear of the filament traces - this is a notorious spot for arcing when the amps are pushed hard. Bend the tips of the legs up and away from the board with a pair of fine pliers if necessary.
It should look like this when done. (One link wire at the lower left, three at the right.)
Hmmm?...Well I do base that on the fact that I have driven the absolute ***t of levels and over long periods of time through a dozen amps . This was done a t max mains (253V for UK) and although into 'nominally correct' loads, both purely resistive and horribly reactive I had very few failures save a valve and sometime a fuse, often one then the other.
I look upon this as an 'accelerated life test' ? If they can stand that sort of punishment for 4 hours continuous at a time then even a load that is a 'bit wrong' will be survived for a decent few minutes?
I cannot of course speak for ALL makes of amplifier! BTW, never had an OPT blow until about my last month when we were testing a different supplier (no, sorry cannot recall the name) 20 mins in an HT Stage 60, Pop!
Dave.
Well I did preface my point with "HALF DECENT! valve amplifier".
Dave.
