Personally I set out to take the basic WR design and improve it for the modern world. CuNiFe magnets are difficult to obtain, horrible to work with, and have proved to be unstable in the long term (many original WRs are now almost magnetically dead). My own Buccaneers use alnico rod mags, slotted to look like pole screws. This gives the defined, 'separate string' sound of the original without the hassle. I also fit four conductor wiring as a no cost option ... to allow very accurate single coil sounds with the right switching. In all other respects the Buccaneer is like a 72 WR ... over-sized bobbins with a big load of 42awg wire (not standard humbucker bobbins as Fender use these days) ... a big, low carbon steel reflector plate, like the original, sat under the coils to fatten up the sound, oh, and the pickups have been calibrated to provide an even response between a pair.
Dusty
But you have to be certain you want a WR sound.
Any good humbucker will give you an ... um ... humbucking sound ... but a WR is a different beast entirely.
Instagram
