SOLD: Tech 21 Character Series Oxford, Boss ODB-3 Bass Overdrive
Tech 21 Oxford: 'Amp in a box' take on classic Orange amps, features switchable 'English Greenback-style' speaker simulation, level, 3 band eq, drive and character settings (which apparently emulates the Orange F.A.C midrange sweep control). The eq settings are very sensitive allowing a wide range of sounds and there's plenty of gain if you need it.
Very useful and versatile pedal this, I've used it in front of amps, for headphones practice, direct in for home recordings. Can be used as a backup amp straight into PA's too, I believe.
Also works well for bass - I used it into the effects loop return of an otherwise pretty uninspiring Markbass amp for a while and it sounded excellent.
Good condition, looking for £90 delivered
Boss ODB-3 Bass overdrive: Handy high/low eq and dry/od signal balance control. Buzz Osborne from Melvins uses these for guitar I think, if that means anything to you... Good condition with some scratches to the paint. £35 delivered.
