Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
If the hardware plating is chrome, I know where you could obtain a Kahler Pro stud mount vibrato.
What do the mini-switches do?
DP3T would be series/split/parallel à la Ibanez Tri-Sound.
With three regular P90s, the only useful options would be phase reversal or series interconnections.
If the P90s are coils tapped, two of them could vary their output levels.
In the second photograph, the lower mini switch appears to be perpendicular to the hex nut and washer. This suggests that it is parked in the middle position and, hence, is a three-way.
Assuming that the neck and bridge pickups run via the toggle selector switch, it would make sense if the the mini switches govern the centre pickup.
On the originals with humbuckers, I think they were a coil split for both pickups, and a phase switch - although I might be wrong, it's a long time since I've played one.
Does it look like factory routing for p/ups, or any suspect changes - ditto wiring - update accordingly for my own interest etc
The most impressive aspect is the workmanship.*
Either the top has been refinished to a very high standard or the P90 cavities have been created without leaving any trace of the original humbucker mounting surround screws.
The four screw holes nearest the fingerboard and bridge would have been assimilated into the P90 cavities. The four innermost screws would be expected to fall outside the "footprint" of the P90s.
* If the guitar left the factory with three P90s, high quality workmanship is only to be expected.
However, I absolutely love the 3 x P90's.
The work looks to have been carried out to a very high standard indeed.
Are we just slapping that word on anything now?
Off the top of my head, I’m guessing this model is around ‘79-‘80, so it’s around 37-38 years old.
Come up with a better term and I’ll happily apply it...
Selling it btw.... if anyone is interested....
http://www.thefretboard.co.uk/discussion/82332/aria-pro-ii-pe60-made-in-japan-still-for-sale#latest
Can't remember where or when though.
Liked it then, like it now. Nice catch H7. Let me know when it's up for the chop
'Old' ?
