Description:
The Irontone io is a medium gain transparent / full frequency overdrive capable of a wide variety of tones with the simplicity of just two controls, Gain and Volume.
Whether you put it at the front of your rig as an ‘always on’ pedal for just a tiny bit of hair, to drive an already crunchy amp into solo territory, or as a stand-alone distortion, the IO is sure to give you the tone you are looking for.
Specs:
True Bypass
Amp Style Tagboard Construction
High Quality, Hand Selected Parts
Hand-Built, Wired and Tested in the UK
9v Centre Negative 2.1mm Barrel Connector
No Internal Battery Option
Please note: There is NO battery snap. This is for two reasons:
a) Space - We would have had to use a larger enclosure
b) Most importantly - The environment. Batteries are incredibly harmful to the environment and the majority of players will be running some kind of power supply anyway.
Instructions:
The ‘io’ is as simple as possible, one switch (to turn the effect on or off) and two knobs. The ‘G’ (gain knob) controls the amount of drive on offer and the ‘V’ (volume knob) controls the amount of output volume. By experimenting with the two knobs in a variety of positions you can achieve everything from a slightly dirty volume boost to a medium, fuzzy tone.
Bump for others.
____________________
www.adamironside.com
www.youtube.com/Adji87
BUMP for the others, still open to trades. eBay soon.
The rest are on eBay but still happy to trade on here.
