orange tiny terror for gigs
nickpnickp Frets: 183
has anyone gigged their terror in a rock band sitch successfully - not from choice but "just in case" - it's only 20w and my gut feeling is that 30w would be betterer
not miked - we only have vocal PA although could mike up if desperate I guess
  • gordijigordiji Frets: 794
    dual terror is a miles better option.
  • would depend on:
    size of venue?
    type of music?
    volume of your drummer?
    any other guitarists?
    do you need clean headroom?
    I gig an orange 15 watt with volume @ 10 o'clock (mic'd through the pa at unity volume to help spread the sound from my 1x10" combo).
    But, I typically play small venues, in a three piece/one guitar band,  playing pop,blues-rock covers with a quiet drummer.
    I could gig without mic'ing up for sure.
  • nickpnickp Frets: 183
    5 piece with a noisy drummer!  rawk.  pub gigs which vary in size
    but sadly not as cheap as chips
    I rehearsed a lot with a tiny Terror 12 combo, it kept up just fine!
    I think i'll get one as s/h they are really cheap and we can always stick a mike on it I guess :)
  • If you want to borrow one to try out for a bit, I've got one and I'm not too far away...
    I've used it a couple of times in a general covers band, seemed to be loud enough but then again, we weren't raaaaawk!
  • newi123newi123 Frets: 912
    edited December 2017
    If you want cheap as chips jet city is your friend here!
    Personally I found the tiny terror was a bit too quiet for rock gigs. The 20w jet cities are fine! I'm just up the road near Swindon if you want to try a jca20hv
    thanks @newi123 - I can't drive for the next 4 weeks but ta for the offer v kind
    nick
    No worries - the other thing I've found with small amps is volume is very cab / speaker dependent. The jet city into their 1x12 with a fairly inefficient eminence meant the amp was working really hard - same amp into a 2x12 with efficient celestions is easily loud enough!
  • Used to play drums in a band where the guitarist used one - had no problems cutting through.
    Into a 4x12 it will be fine
    i use a 2 x 12 normally
  • Not a Tiny Terror, but I have an 18w Marshall clone as backup. I've used it for the second set to make sure it still worked and it was fine, through the speaker of a 1x12 JCM900 combo. The band was a 5-piece pub-rock covers band with a noisy drummer.
    Which one
    i have a closed back orange 2x12 that would give a 4x12 a good run
    i gigged a tiny terror for years with my chillis tribute
    I moved up to a dual terror but bear in mind I was doing a lot of cleans
    I’m pretty sure this was the dual terror
    https://youtu.be/0Deu7JUrEdY
    Bt this was definitely the Tiny Terrie although Pa miced up
    https://youtu.be/dRH3XQrAws8
  • I used a mini stack of dual terror and 2 1x12 cabs. It was awesome.
    thanks everyone.  of course the other side of the coin is to save up some gigging dough and get a s/h kemper :)
