FS Bright onion pedals input selector and loop + custom killswitch/mute
JtaylorJtaylor Frets: 182
edited March 2015 in FX £
Bright onion pedals, has two functions, you can plug two guitars into it and then choose between them with the footswitch so it saves you changing leads over to other guitars. It also has a true bypass loop, the pedal itself doesn't require any power so if its not plugged in itll still work but for the leds to light up theirs a standard boss type socket £30 ono
This pedal I had custom made, it simply mutes whatever signal is going through it, I used it to mute my pedal board and to tune, its battery powered and has a little switch to turn of the led when you've finished playing. the led will shine green when the signal is going through and red when muted. £20
open to trades aswell
located in nottingham
Thanks for looking
