I've been using a 100W L-Pad with my 5E3 for a while and was used to it being there. However, after removing it recently to lend it to someone, and then a couple of weeks later reconnecting it, I noticed that there is a significant loss of volume and high frequencies even when it is not supposed to be attenuating at all. Measuring across the jack terminals in and out, I'm getting 0.8ohms (no attenuation) through to about 36ohms (the highest measurement before the last turn of the L-pad when it reaches infinite resistance). I thought L-Pads did not affect volume or tone when they weren't attenuating at all. Am I wrong?
I know I did this once, but I can't quite recall the actual numbers I got. It did go up and down a bit, but nowhere near the 0-infinity that you have and not enough to worry.
If you post a photo of how it's wired up, we'll be able to double-check that it's connected right. I'd post a pic for the hook-up of a typical L-pad (the Monacor that CPC sells), but it seems that attachments aren't allowed here.
Measure the resistance between the input tip and ground, with the level up full and nothing connected to the output.
Resistance is 9.2ohms. Why isn't it zero?! I don't understand why it is loading the input when it is supposedly bypassed.
goldtop said: For sure, if you attach a speaker to the output, and then measure the DC resistance across the input, while you sweep the L-pad's knob, you should see numbers closer to the nominal L-pad's impedance. (NOTE: the whole kit and caboodle must be unplugged from the amp to do this.)
There was no speaker attached - I was trying to measure minimum resistance, but obviously was using the wrong method. Surely an attenuator should have a sweep of zero to infinity resistance?
...shows how there are two resistive elements that are swept at the same time to achieve this (near) constant load.
So, the speaker sees anywhere from a near-zero to near-full part of the amp's output depending on teh position of the dial.
