I don't need to switch in any hurry though, it's mostly just bass pedals which I use to get a sound and then stick with it typically.
I did consider a board but it seems more hassle than it's worth, it's easy enough to add/remove/reorder with them just on the floor. Adding a board and using velcro seems an unnecessary step to me for home recording but YMMV
https://i.imgur.com/tg31cPu.jpg
There's things I've had, there's things I wanna have"
Most of mine are on two music stands so as to be in twiddleable range.
But yes, thanks @OnTheRopes for the mention - and to @mistercharlie - I got that made, but any coffee table height surface works for putting it near a swivelling desk chair and saving you from plonking your ass down on the ground for hours on end. The nice thing about this setup is that everything is still attached to the pedaltrain so it's portable enough when need be. Although I do like @Paul_C setup if you're a standing player!
I’m thinking a projector stand might be the way to go. This one holds 20kg and I like the ridges at the edges.
I have a Custom Pedalboards board, but have thought about buying a keyboard / mixer / dj stand or somesuch to raise it to a more tweakable height...
