OCD vs Tumnus
bassborabassbora Frets: 132
I have an OCD but I was thinking about more options and Wampler Tumnus has caught my eye.  Since I dont know much about circuits I dont know if these two pedals are similar or not.  I know that the Tumnus is a Klon clone but I have no idea where the OCD sits in all of this. Could anyone shed some light on this for me please
  • Pretty much opposite ends of the spectrum. Tumnus is very soft, low gain, edge of breakup kinda sound, up to a medium gain vintage tone.
    OCD is basically a Marshall-in-a-box; much more aggressive. They'd work well together on the same board but they're not interchangeable I'd say.
  • smudge_ladsmudge_lad Frets: 666
    edited January 2018
    As @colourofsound has said above, but you'd be best checking out some youtube demo's to hear the basic differences for yourself. They should be fairly obvious once you get a listen to both of them.
    The new Tumnus Deluxe has an added toggle switch to add more gain/clipping tot he circuit, which might get you closer to the OCD territory in terms of available gain, but even with the 3 band EQ, it will still sound fairly different to the OCD tone wise.
  • bassborabassbora Frets: 132
    Thanks guys for your replies very much appreciate it
  • johnhejohnhe Frets: 191
    A Klon style pedal would be a great pairing with an OCD imo. The Klon would be great for pushing the OCD for solos. As would a tubescreamer.
  • mrkbmrkb Frets: 6837
    Isnt a klon style (tunmus) into and OCD style pedal what the Keeley D and M drive is? that seems to get good reviews - check out youtube to get a feel for what that combo could do.
    Karma......
    Ebay mark7777_1
    Has anyone tried the new Tumnus Deluxe and are you getting that much more than true by pass and bass and mid eq?
  • crunchmancrunchman Frets: 11451
    I've heard a Soul Food (Klon clone) used to push an OCD this way.  Sounded great.
    The Klon (and the various clones of it) push the mid range a lot more than the OCD.  A lot of overdrives do that where the OCD is much flatter in terms of EQ.  I love the OCD but it can disappear in a mix if you aren't careful.
    I know a lot of people use it with the gain higher but I do like the OCD on 18V as a low gain pedal.
    Does the Tumnus have a bit more low end than a lot of Klon clones?  I'd quite like to try one.
  • thomasw88thomasw88 Frets: 2326
    the answer is strymon sunset.
    The reviews I have seen usually say that the Tumnus has more bottom end than other Klon clones. Don’t know if that’s a good thing or bad. Probably depends then on the rest of the rig, amp and guitar.
  • Adam_MDAdam_MD Frets: 3420
    Me too it’s wonderful as low gain pedal at 18v.  I’ve been toying with the idea of putting two of them into a 1590bb so I can have individual low and high gain sides.
    Yup - I’ve been usung mine that way too, great combination. The Ge mode has completely replaced my WH Saucy Box too (Klon-type).
  • The tumnus really has an audible bass boost. I can definitely hear it on mine and for now I can live with it. It sounds great, but if I was to make the choice at this moment, I'd go with the deluxe version. The regular one sounds great and I dig what it does to the sound, just keep it in mind.
