Hi
I've used one of the original Nova System pedals for a few years and, well, other than the overdriven sounds being a bit lacklustre, I suppose it's done OK. A bit quirky but, once set up and being careful not to do anything different - like doing ANYTHING different - it was OK for the absolute basics. One very expensive, large and heavy box replacing two or three standard stomp boxes, maybe...but OK.
However, I had a major issue a few months back - luckily in a band practice - where basically the presets still worked, but in pedal mode there was nothing. Unless you put 'Drive' on and then it was so loud it threatened structural damage. And even with the presets, turn the drive footswitch off (local noise bylaws require such things with most multi-effects pedals...where DO they all get their non-volume balanced presets from, for goodness sake?!) and ear-bleeding volume reduces to absolutely nothing. Basically, if the drive switch was off, there was no signal at all. Not even any response from the Input Gain indicator in the Utilities menu. I did a factory restore but same problem.
Spent today really starting from scratch
- loaded the latest firmware
- did a factory restore
- tried all sorts of permutations and combinations
- sent an email off tothe email address TC Electronics say are their UK repair centre
Without going through all of the detail, I've managed to kid the Nova into getting to what I want as the basics - basically I've got Drive engaged all the time, but with zero Gain and, using the 'Bypass All' preset, have created a clean preset and, on a separate preset with SOME gain on the drive options, have also created an overdriven preset. So I can basically turn the overdrive on by changing presets.
In the meantime, I've received a bump-back from the email server saying that the TC Electronic Support email address doesn't exist.
Although I'm irritated that the Nova was never ever as good as I think it could have been, nevertheless it was expensive and there is ONE combination of settings I really can't replicate with 'normal pedals'
So, should I persevere and try and find a competent service centre (anyone know of one?) or just bite the bitter pill and bung it in the 'Small Appliances' section of the local tip?
It worked!
At first I was a bit doubtful because only one chip was in a holder - all the rest were soldered. But I duly pressed them all firmly and - sorted!!!!
But more than just sorted. Remember my rant about patches that are all over the place with massive volume variations that has been an irritation of this pedal from new? Bloody well sorted!
I'm so pleased - thanks hugely for the tip
Andy
