I'm a complete newbie to switching systems I'm not even sure if it's worth adding one to my current set up and I can see how they would be utilised for live use.
I've researched a couple of the Boss offerings but I still don't really understand how they work.
For example I've got quite a few settings I like on my old Boss OD-1 and DM-2w are you saying that these switching systems like the ES-5 can save your favourite settings as individual patches in the internal memory? and that you can recall those saved parameter settings any time? How does that work on analog based pedals? I thought these switchers only worked best with midi based pedals? As I say I'm completely new to this any help would be greatly appreciated.
This is useful if you use different combinations of effects all the time and need to switch between them quickly.
Since the ES-5 can also send MIDI messages (patch changes and control changes- altering parameters within a patch), you can see how the options open up dramatically if you have a few MIDI-enabled pedals, but it's not required.
There's a ton of other stuff the ES-5 can do, but that's the core of it. If all you want is the loop switching there are much cheaper ways to achieve that. As far as I know, the only way to get multiple settings on basic analogue pedals is either to change them on the fly, or to have duplicates of the same pedal on your board.
Another thing I use it for is switching my amp channel or switching to a favourite setting on my Strymon sunset.
