How black do you want your guitar to be?
ChalkyChalky Frets: 6813
Imagine a guitar body that is THIS black...
  • JerkMoansJerkMoans Frets: 9121
    None more black
    Inactivist Lefty Lawyer
  • carloscarlos Frets: 3691
    Vantablack S-VIS can be applied to a wide range of material types. The only major requirement is that the surface or substrate material must be able to withstand temperatures from 100°C to 280°C - The actual temperature depends on the substrate and end use.
    I wonder if 100C is too hot for applying on wood.
    I'd try to apply it to a covering material which could then be glued or otherwise fastened onto the guitar body. Then I'd put the covering on an SG such that Zaphod Beeblebrox would say "That is really bad for the eyes ..."
    Presumably it would play itself before crashing into the nearest sun
  • SteveRobinsonSteveRobinson Frets: 7343
    No (it's the temperature of boiling water) but at 280C wood will char or ignite.
  • JerkMoans said:
    None more black
    It's something you wear around your arm. You don't put it on your fackin' turntable!
  • That's right, Dougal. You see, ordinary shops sell what look like black guitars, but if you look closely, you'll see that they're very, very, very, very, very, very, very dark blue.
    Never buy black guitars from a normal shop, they shaft you every time.
    Check out my band Coral Snake if you like original hard rock!
  • mbembe Frets: 1840
    Priests' socks.
  • steersteer Frets: 1233
    edited February 2018
     That's true. I thought my Uncle Tommy had a black guitar, but when I looked at it closely, it was just very, very, very, very, very, very, very, very, very dark blue.
  • That Lollipop is about as Black as the Earl O' Hell's waistcoat.
  • FunkfingersFunkfingers Frets: 15262
    Obsidian darkness, as Mr. Sting would say.
    mbe said:
    Priests' socks.
    I just searched for the video clip of that gag. According to the YouTube caption, Channel 4 has blocked access to it in my country. Feck! Arse! Drink!
