Invest your disposable funds in better pickups and a smartarse switching system for the Les Paul. True, this will not yield the exact sounds of Fender type guitars but it should cover most musical bases.
My recommendation would involve either push-pull pots, the Freeway 3x3-03 six-way selector switch or Seymour Duncan Triple Shot mounting surrounds. None of these is cheap but the result will be a guitar that you will enjoy using.
I loved the pickups in my CP50s strat, not so much the v neck though..
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
Yup. If the rest of the guitar is right then the pickups can easily be changed at a later date. If the radius or frets don’t suit then that’s much more of a problem.
I think this is really quite a mystery and think it's often assumed that the higher end Mexican fenders differ to the standards in more than just the paper specs.
