Good point though, I haven’t tried it with its own power supply yet! Thanks.
By the way I have a Strymon Sunset and it's quiet as a mouse using that with it
I'v checked mine and no extraneous noise ..
Thanks but I need an ISO brick or anything else that gives 8 x 9v outs and 2 18v outs. (Not sure if anything else does?!)
@jonnygreentrees nope, no klone!
It must just be because i'm drawing near the limit of my DC brick.
Took the line 6 m5 out and all was well. It's a very fussy pedal power wise
If you need 18V at more than 30mA you can get voltage doubler cables that will use two outputs of an isolated supply and put them in series to get 18V. Don't try one of those cables on a non-isolated supply though.
If you do get something that only has 6 or 8 outputs, you can put 3 or 4 pedals together on a daisy chain cable. That's basically what the DC brick does internally anyway. I've got 11 pedals running off of a Decibel 11 Hot Stone Deluxe that has 8 outputs.
I had problems with the older Dunlop version of the DC brick and high pitched noises in the past. That's almost certainly your problem.
