Yeah fair enough - would just love a Bluesbreaker and be able to play it at home as well and my current Marshall 1W Offset head and cab is about the right volume for that.
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
A Bluesbreaker is a JTM45 circuit which will run 6V6's to get it down to about 20W, a Powerbrake attenuator would make it quiet enough for playing at home. It's a lot of expense/faff though
Thanks for chiming in.
Cant comment on the bluesbreaker circuit but power scaling sound shite in my 18watt!... it reduces the b+ across the whole circuit and just does not work!...
the L pad works tho’
Or if it's a Bluesbreaker with the deep cabinet you could fit a pair of EL84 converters like this:
http://www.tubeampdoctor.com/en/shop_TAD_Equipment_TAD_Class_A_Converter/TAD_CLASS_A_CONVERTER_5235?selected_slave_id=669
Which despite the name do *not* run the amp in Class A, they operate in Class AB as usual - but probably close enough to Class A that you could get away with fitting only one and operate the amp single-ended.
You could also replace the GZ34 with a 5Y3 if you're going to reduce the available output power like that, which would drop the voltage and further reduce the power. You probably won't be able to get down to under about 5W like that, but it will be a *lot* quieter.
I believe they'll be available in May. I played the 20 watt at the Guitar Show on Saturday and it was really nice. The 0.5 watt setting would be ideal for home use. I had the gain and master on full and was still well within the volumes I currently use at home.
It sounds closer to a Plexi than anything else to my ears but I didn't bother fiddling with the EQ apart from the Tilt. Enough gain to get that classic Marshall crunch but by no means a high gain amp. It'll make a great pedal platform though.
