AD30s blow rectifier valves because the standby switch is in the wrong place. Luckily, if you fit a simple plug-in solid-state rectifier it both fixes this and makes the amp sound better - less muddy and overcompressed.
Dual Terrors seem reliable enough but have a quite a fatiguing tone in my opinion. Some people like them though.
Both the last two use EL84s and are quite hard on them. They're all well-made and generally reliable apart from the AD30 rectifier problem though.
Personally I think the Rocker 30 sounds better than any of them and also uses EL34s, but it has no EQ on the clean channel and no FX loop, and is discontinued although not that rare.
You'd only find one second hand at this stage, but if you can find one, they are certainly worth testing to see if they scratch your itch.
Re the Rockerverb, the reverb on the reverb on the MkII is a bit over the top.
There were a couple of issues with the MK I and MkII that have been corrected in the MKIII, which in my opinion is the best built of the 3.
