Helix LT & Mission pedal help please
PittsterPittster Frets: 15
hi there,
apologies if this is a really stupid question, but I have acquired a Mission SP1-L6 Helix pedal (with toe switch).
I have a Helix LT. I understand that the Mission toe switch does not work with the 'floor' models of the Helix.
My question is will this Mission pedal be of any use with the LT? Could I use the on-board expression pedal as a volume control and the Mission as a wah? If yes then how would it work bearing in mind that the toe switch doesn't work on the LT/floor model?
thanks for any help/advice.
  • rossyamaharossyamaha Frets: 2462
    It will work fine. Because the toe switch works on the LT, personally I would use the LT expression/ switch for the wah and the mission for volume. Alternatively you can assign the auto on for the wah and use the mission for that. Switchlesswahtastic.
