I've wanted one of these for a long time and finally one came up on Reverb. They use all octal valves, 5Y3 rectifier, metal cased 6SQ7 preamp, 6SL7 inverter and 2 6V6GT power tubes. These give it a 12 watt class AB push pull circuit. that is cathode biased and it has a 10 inch Weber alnico speaker.
The sound was everything that I had been hoping for. It has great cleans and can drive a bit when pushed. I am still in the honeymoon period and haven't tried it with pedals yet, as the clean tones are so good. Just a volume and tone, with 3 inputs, which all have slightly different sensitivities, so you can get a bit more drive as you go through them.
i have the Suitcases model, similar to the Spectator. I may sell it, only cos a pal made me a Spectator clone and they do sound very similarly
