what a bloody mind field.. Birthday has come and gone and my head is about to melt..
been looking for a desktop that is capable of playing modernish games not necessarily at the highest settings.
there are so many processors etc.. now I am struggling.. probably stretch to £600 don’t mind reputable 2nd hand..
where I am at.... I was considering the Alienware Steam Machine/Alpha i7 but so many problems with ‘yellow light of death’ and having to do constant power drains that buying used(the only way to get one) is just too high risk.
1060,70,80 have all suffered a nasty price hike due to crypto mining. I'd also be a little wary of buying a recent 2nd hand gpu, I would panic it has been run into the ground mining.
In terms of CPU performance I'd say the AMD Ryzen 5 1600x is probably the sweet spot in terms of price/performance, especially as the new Ryzen 2 CPUs are going to be released April 19 so there are some good price cuts around.
Here's a possible spec I've put together (minus monitor & Keyboard).
CPU - AMD 1600 £150
Motherboard- Gigabyte GA-AB350 £70
Memory - Corsair Vengeance 8GB DDR4-3000 £97
OS Harddisk - Western Digital Green 240GB SSD £62
Data Disk - Western Digital Caviar Blue 1TB 7200rpm £35.99
GPU - Palit Geforece GTX 1050 2GB £110
Case - BetFenix Nova ATX Mid Tower £30
Power Supply Corsair CX500 £49
Total ~ £606
Alternatively if 720p gaming is enough for you, you can go down to a AMD 2400G APU and scrap the GPU
giving you a total price of £477 (you can always add a GPU later) for a decent monitor.
You will then need to supply the Windows license/keyboard/Mouse and monitor
This should do you well for 1080p Gaming are medium to high detail at good frame rates and will be future proof (AMD have stated they will keep the AM4 socket till at least 2020.
Probably not just basing on the Alienware I was looking at.
Combine it with a 1060 (£260)
and you're in a good place for some gaming... add in a motherboard for about £150 and hope you have an SSD and power supply? and a cooler... or scrimp a few extra pennies together for those, and a cardboard box would do as a case until you can get a better one
I7 6700
256gb pci-e ssd (the fastest type, although gains over a normal sata ssd are probably not huge)
16gb ram
Gtx 960 graphics card
2tb disk drive
It's a bit of a beast, and the card can be upgraded to a small Gtx 1060 if wanted as it has similar power requirements. I play doom at medium settings with no noticeable frame rate drops.
I mostly use the PlayStation though, as the computer is really for photo editing.
So I'd not scrimp there but look to buy a used graphics card as some people upgrade pretty regularly so there a few bargains to be had.
If I was to rebuild I'd be looking at an i7 this time.
https://www.hotukdeals.com/deals/asus-gd30-core-i5-7400-8gb-2tb-256gb-ssd-geforce-gtx-1070-windows-10-gaming-desktop-in-black-and-white-79997-laptops-direct-2909582
Intel are currently way over priced at the moment. Due to the large monolithic die (Compared to AMDs glued together small dies)
If you compare an Intel i7 6700k (quad core 8 thread) it will set you back £278.
For an AMD 1600 (6 core 12 thread) which is compatible from a single threaded performance point of view and 50% more cores Going for an AMD build is a no brainer.
Alienware Alpha R2 Steam i5-6400T 2.8GHz 2GB AMD M470X 1TB 8GB W10
so I will see how it goes and see if does what I am after.
