Don't ever put a distortion, fuzz, overdrive or amp-preamp type pedal in the loop - it will usually sound bad anyway, and can sometimes make the amp self-oscillate outside the audio range, which will sound even worse and in rare cases can damage the amp. You can run a pedal like this *into* the FX return to bypass the amp's own preamp, as long as it isn't being fed with a signal that comes from the FX send (even via other pedals)... if that makes sense!
Wahs won't cause any harm in the loop but generally don't sound good. Some other pedals have too low headroom to work well in a loop - they will reduce the volume and add unwanted extra distortion, although it also won't do any harm.
Does that help?
Where to put the looper depends on what you want to do with it, but in general most people would put it in the loop. That way you can set up a loop with a rhythm sound on the amp, then switch channels and play over it without altering the sound of the loop. Whether before or after the other two depends on how you want to add the reverb and delay to the looped parts.
