Good day! Proper equipment noob here! I’m after the solution to be able use my Boss ME-70 multi effects pedal through an amp. Struggling to find any answers online, hence why I’ve turned to this forum and it’s users’ infinite wisdom.
I practice using my ME-70 with headphones plugged straight into it and love the sound I get from it, it’s not until now that I’ve needed this sound to be played through an amp! I have a Line 6 amp that I originally used for practice, tried plugging the ME-70 straight into the front of that and it sounded rubbish, even with clean amp settings. I’ve read somewhere that Line 6 amps are not good in conjunction with effects pedals, is that because even on clean settings they still use digital trickery to effect the sound? If so, what amp is a suitable alternative to be used with an ME-70? I.e an app with truly clean preamp settings.
What I have found is people mentioning putting the effects pedal into an amps effects loop, a feature my Line 6 does not have! but from what I can work out this will still create a poor sound, as the preamp will still be altering the input sound before it reaches the pedal. I want ideally to completely bipass (not use) the preamps settings, is this even possible? I’m beginning to think not! I’m assuming an effects pedal could not power a cabinet as isn’t that essentially what I want? The ME-70 as the head, plugged into a cabinet to create a stack? I have a feeling that is a completely noob outlook on it... Another protential solution I came across was the use of a PA speaker however I have never seen a live guitarists rig with this set-up which leads me to believe there is an alternative?
I know im probably an optimist thinking I’ll be able to recreate the exact sound I get through headphones through the amp (I know that’s impossible) just want a solution that still allows me to quickly change between patches and get a sound effected as little as possible by the amp. I’m willing to purchase additional equipment, I’m thinking it is simply my Line 6 which is the problem?
sorry for the essay, and thanks in advance for any help!
More knowledgable folk will be along shortly.
First of all, the level from the ME-70 is likely to be much higher than a passive guitar voltage and is therefore overloading and distorting the L6 input, and not in a nice way!
Secondly, a headphone output is "stereo" and to feed a mono amp input the signals must be resistively 'summed'.
If you can solder I can tell you what to put "in the tin".
Dave.
If that's the case then what's happening when you plug into the Line 6 is it's trying to add more amp modelling on top of that signal. 9 times out of 10 that will result in a muddy mess, as you've found. Not sure what L6 amp you have, but I assume probably some sort of Spider as that's the standard amp that has sold the most.
So you have 2 options:
1 - you can switch off the preamp stuff in the ME70 and use the amp sounds in the Line6 amp you already have. You'll want to use an amp model in the Line 6 that is equivalent to the one you would have used in the ME70 in terms of gain level and general tone. This may sound great, in which case you can stop already. If that doesn't get you what you want, keep going
2 - you need to plug your ME70 into a power amp and use its onboard preamp section. If your existing amp has an FX loop then you can use that; just plug the ME70 into the "FX Return" and use the master volume on the amp to control the overall volume.
If you have no FX loop, then you'll need either a different amp that does have one, or a separate power amp and speakers.
Lower end digital guitar amps aren’t designed to manage hotter signals going in. So, if the patches from your ME70 include any level of boost it’ll probably sound crap. You might find that if you play around with the levels on your patches so the output is closer to the unadulterated guitar it might be better.
In practice what works through headphones and what works through an amp aren’t always the same thing. You could look at sorting new patches that work though the amp. Guitar amps, even budget digital ones, aren’t designed to be flat response make louder devices. They are intended to sound like guitar amps. Plug something like an MP3 player into your Line 6 and see how crap that sounds, that’s not a fault with the amp it’s just how it’s meant to sound.
If if you are using the amp in order to play with others you might find you need to cut down on or change your patches anyway. More complex sounds that work great through headphones can be completely lost in a band context and tend to sound waspish. I think the ME70 includes amp modelling, although you could try the amp models on and off through the Line 6 but I’d guess they will generally sound better off.
If it were me I’d try to work towards having the one set of patches for headphone use and a simpler set for using through the Line 6 - using it’s amp modelling and using effects only from the ME70.
If you want to simply cleanly amplify the ME-70 and not use the sound of the main amp at all, any half-decent old solid-state analogue amp will work, possibly even a keyboard amp - these all tend to be cheap now. Peavey, Laney, Carlsbro, even Marshall all used to make amps like this which typically sell for £100 or less nowadays.
The alternative would be to use the headphone output of the ME-70 (which is speaker-emulated) into a powered monitor, which will actually give you the closest to the sound you're now getting through the headphones. The line-level input of a powered monitor should be fine with a headphone-level signal. You'll need a stereo-to-mono cable, most likely.
I had never really thought about the switching between Mono and Stereo, to my untrained ear though, it sounds more like a problem with too much effects being used at once. I will though go into it with an open mind considering this change from mono to stereo. However like you and everyone else has touched on, I think its more the settings that need to be investigated.
Thanks!
Is there any way around this overloading/distorting? Sorry if this is obvious!
During trialing the amp with the pedal I did used the LH output to create a mono output (at least I hope I did, it is labelled...) so i'm assuming this functionality sufficiently 'sums' the tone.
Just want to make sure I follow on step 2... So purchasing a new amp and plugging the ME-70 into the FX return will essentially bypass the amps preamp? Because of this I can use the ME-70's preamp section once again, and the next step of the chain is just sending that signal to the power amp section of the amp?
I'll be sure to try step 1 first though before rushing out and buying another amp!
Also, if you do have an amp with an effects loop, you should not put the ME-70 *in* the loop. (ie guitar > amp > FX send > ME-70 > FX return.) That can cause feedback and potentially damage the amp, although this is quite rare. What to do is bypass the amp's preamp by going simply guitar > ME-70 > FX return. That will avoid creating a feedback loop and will also probably sound better.
When I've 'fixed' the muddy/waspish sound i'm getting, hopefully by using one of the two steps highlighted by stickyfiddle i'll create additional patches for both headphones and through an amp both with and without the ME-70's amp modelling (on with headphones and off with the amp).
I'm really not that familiar with any of the FX, I can see you all cringing! I'm going to spend a good deal of time doing some proper research and playing around to fully understand how the tone is coloured with different effects.
P.S. I have no idea why that's come up as a link...
I'll have a look at a these amps manufacturers/types if I need to go down the route of a new amp. I have tried it through a computer when playing with audacity and you're right, the sound was pretty darn identical to what I was hearing through my headphones!
I switched off the preamp section, used the EQ on the amp and then set distortion/modulation etc on the ME-70 to taste.
The headphone out switches on a cabinet simulation when you plug into it so if you do decide to use a PA from the L/R outputs, you need to plug in a headphone jack to switch the cab sim on. Or use a 3.5mm stereo cable and plug that into the PA.
The ME-70 is a very underestimated unit and I still use mine which I bought new in 2009.
Ta
Start with them all halfway, or slightly scooped (bass and treble a bit above half, mid a bit below) and adjust from there if it still doesn't sound right. Set the master volume up high - maybe even full, if that doesn't produce too much hiss - and the gain as low as possible to get the level right. Try it with the guitar straight into the amp first, then set the ME-70's output level to match that - that way you'll be sure you aren't overloading it.
I certainly find that stacking one lot of modelling into another often causes problems. Essentially, the second modeller is expecting a fairly clean guitar signal, or at most an analogue overdrive sound, so it often doesn't seem to respond as predictably to something more complex. Using the cleanest possible sound on the amp should hopefully stop that.
Thanks.
Thanks!
