So, I have an Omega Geneve which I believe is from around 1975. I managed to pick this up a couple of years ago in a charity shop and fortunately it keeps excellent time. However, several months ago I noticed an issue with the date complication. When it tries to change from the 1st to the 2nd, it flicks back to the 1st. You can manually change it to the second, but it would be out of sync that way. Does anyone know what the cause would be and whether or not it'd be a relatively easy fix? The reason I ask is that I'm thinking of selling it on to raise some funds. Obviously I'd get more if the date worked properly. Even I didn't sell it, I'd still like the date to function as it should.
@Neil You're our watch guru. Do you happen to have any ideas?
https://twitter.com/spark240
Reddit r/newmusicreview
Mine needed a service and we used people called Watch Kings on eBay and they did a great job. They also did Mrs Fred’s Geneva too. The only issue was they were a little slow but they fixed both watches when others said it couldn’t be done for a sensible price.
Flanging_Fred said: I found an old 1970s Geneves in a charity shop too.
Mine needed a service and we used people called Watch Kings on eBay and they did a great job. They also did Mrs Fred’s Geneva too. The only issue was they were a little slow but they fixed both watches when others said it couldn’t be done for a sensible price. Thanks for this too. I will look in to this.
One thing I would add is to never manually change the date between 9pm and 4am as you can damage the mechanism.
Hope you get it fixed OK these are good quality watches and your blue dial looks lovely, most are silver.
'Uncluttered' is exactly what I like about it.
I don't need to get into watches though. Between guitars and woodworking my money seems to evaporate quite quickly enough as it is.
If you use the crown to change the date during the period it is under tension you can damage the day-date gear or the disc itself which can become brittle with age anyway.
To illustrate, here is a pic of a date wheel (not yours) which shows how easily the plastic teeth can be sheared off by setting at the incorrect time period.
