Pro Junior Blonde 1995?
JerkMoansJerkMoans Frets: 8794
Anyone got any experience/opinions on these little pocket rockets?  Been offered one in a partial trade for something and pondering it.  I presume it's nothing like a Champ, save in looks: more like a baby Hot Rod Deluxe?
All observations gratefully received, as ever.
Inactivist Lefty Lawyer
  • thecolourboxthecolourbox Frets: 9850
    I had one, lovely little amp albeit a little bit hissy - don't think they all area just depends on luck of the draw I think. Main reason I got rid was that it only did clean quietly and drive loudly which is the exact opposite of my use case. It doesn't sound like a Hot Rod, sounds a million times better than a Blues Junior, not played a champ to know on that one.
    I don't think there is anything different about the Tweed version of the Pro Junior Fromm the standard black one apart from the livery
    soundcloud.com/thecolourbox-1
  • JerkMoansJerkMoans Frets: 8794
    Wiz'd and thank you.  A million times better than a Blues Jr is a good start :D
  • munckeemunckee Frets: 12414
    Ive tried them a few times, too loud for home use I found but great sound. I have a 5 watt champ with 5 f1 circuit and they are not very alike.
  • octatonicoctatonic Frets: 33821
    1995 might be a USA made one.
    I used to have this committed to memory but it escapes me now.
    Yes it is
    Yes it is
    More valuable then.
    Nice amp, better than the Blues Junior.
    I like doing head conversions or putting them into 12" loaded combos.
    octatonic said:
    Yes it is
    More valuable then.
    Made by Mexicans in America, rather than by Mexicans in Mexico
    octatonic said:
    Yes it is
    More valuable then.
    and therefore more valuable.
    I'm not saying it isn't mad. :)
  • p90foolp90fool Frets: 31640
    My first one was a blonde 95, it sounded fabulous and was very loud. I gigged it in a seven piece soul band using an attenuator.
    Some of the early ones had a panel screw which was too long and caused a hum by touching the volume pot, although mine was ok.
    They're a little brash sounding but work perfectly in a band mix - just don't expect deep, Fender Twin-style cleans, it's a bit more Vox-like than that. That's through it's own speaker, through a 2x12 it's a glorious sound, much bigger and deeper. There's not much point in doing a head conversion though, it already has a speaker jack and is small and light anyway.
    A word of warning though, they can be addictive and you'll end up wanting to run a pair of them.
  • ICBMICBM Frets: 72521
    octatonic said:
    Yes it is
    More valuable then.
    But slightly less well-made than the Mexican one...
    Still not bad though - there's less difference with the PJ than the BJ.
    If it's very hissy, check that the Zobel filter on the OT primary isn't faulty - either a failed resistor (which will make it hiss) or sometimes a shorted cap (which produces a very low output) is a known issue.
    I could be wrong but I think the blonde LE version came with an Eminence alnico speaker, as was fitted to the Bassman reissues of the time.
  • springheadspringhead Frets: 1601
    I've still got the US made blonde Pro Junior I bought around 94, 95.  It's not a typical Fender circuit, so doesn't do the Fender clean thing.  It's more like a Marshall 18W (though not quite that circuit).  They're loud, and need to be turned up to get the best out of them.  That and the inherent hum/hiss they tend to have means it's not a home/recording amp, but they're a great live blues/rock machine.
    They run the EL84's too hot, on or over the max anode dissipation.  Modding to variable bias and backing it off a bit is a good thing to do.  I've also put better pots and jack in mine and changed some of the passive components for better quality/lower noise.
    Having said all that, I'm going to sell mine.  I built a tweed Deluxe recently and hence don't need the Junior anymore - but could do with the funds to pay for the Deluxe!
    Oh - look up Jeff Beck videos on YouTube - he sometimes gigs with a pair of them.  The Rock and Roll party video was one occasion.
  • CountryDaveCountryDave Frets: 858
    I had one for a while.  I mainly gig a Blues Jr but took this to a couple of gigs (mainly because it was even easier to carry up stairs).  The sounds were great, but at the volume I needed it did tend to break up more then the Blues Jr.  I loved it, the singer said it was too distorted (it wasn't) ;)
