4010 Clipping the bright cap
HootsmonHootsmon Frets: 16007
What is this mod and what does it do / what is the difference?
tae be or not tae be
  • ICBMICBM Frets: 72736
    Makes the amp less bright :).
    There are actually three possible caps to remove - two will make the amp less bright at all settings, and the third will have less effect the further up you set the preamp gain... if you usually set the gain up full, there's no point in doing that one.
    It's best not to fully remove the cap but just to cut one of the wires, so it can be easily put back if you change your mind.
  • MoltisantiMoltisanti Frets: 1134
    edited June 2018
    i tried it both ways and left it stock in the end, you can easily dial out the highs with the presence and treble
    the most important thing with these amps is speaker choice, it makes a massive difference.
    With a G12 T75 it sounds OK, with a 75w Creamback it sounds awesome
