So i'm re-jigging my partscaster to have an HSS pickup configuration. I've got neck and middle as fralin vintage hots, and i've recently acquired a JB which i intend to slap in the bridge (pickup screws courtesy of Van_Hayden
Anyway, i've been reading up on it and it seems theres some mixed opinions over what pot values to go for. I gathered that the standard for HB's is 500k volume and tone, but i've been reading in a few places that the JB is suited to a 250k volume, and can sound harsh with a 500. Other places however, have said that the 500k opens out the highs, and a 250 will sound like a wet blanket over the amp (paraphrased)
At the moment i've got a bourns 500k push pull volume, CTS 250k tone (neck and middle) and CTS 500k bridge tone. I've also got a 470k ohm resistor which i'm going to use across the switch to trick the single coils into thinking that they're running through a 250k volume pot, which i found on a Dimarzio diagram and seems to be the best solution.
(Long ramble over)... I was wondering if anybody had any experience with the JB, as i've never actually heard one, and the apparent pot-values debate, and whether you think what i've opted for is a good solution, or if there's any obvious improvements.
Cheers
what you are saying sounds like it makes sense but...................... i don't really understand haha. Is there any way i could find a graphical representation of it? Nothing i have come across so far has a resistor on the coil tap, does that make the volume pot into a virtual 250k when the tap is engaged?
Single tone a standard switch works great, I didn't read that bit...
