Ohmage question
lentolento Frets: 117
Just checking if it's alright to run a 16ohm speaker and an 8 ohm speaker from the left and right channels of a Palmer 402 stereo power amp - no valves ! Presumably the 16 ohm speaker would be a little quieter given equal volume ?
    According to the Manual it should be ok as long as they are 4 ohms or higher. SS amps don't usually mind a higher impedance but anything below is a risk.
  • lentolento Frets: 117
    Great ! Thank you  :)
