Hi all
I have a squier Jazzmaster baritone (antigua green) and about to upgrade parts on it etc.
Down the line I am considering refinishing the body in a natural colour.
Not sure id be able to do it with the current body/finish.
if not and I have to source a new body, what should I be looking for seeing as the baritone has a hardtail bridge.
ive had a look on warmoth out of curiosity and there are a lot of options...
The Fender vibrato looks cool but can cause no end of problems - especially in budget form. Hence, the fixed bridge is a good idea. If you are installing one on a new, undrilled, JM body, just mark out correctly.
The wisdom of mating one hundred Pounds' worth of Indonesian neck to several hundred Dollars worth of American body is open to question.
