If you keep the V30: Classic Lead 80.
If you go for a G12H-75, also get a G12M-65.
No point in mixing a G12H-30 with a G12H-75, they're very similar sounding but totally mismatched for power rating, so you'll have to push the H30 too hard before the H75 has a chance to do much. (The same reason as why I don't like the H30/V30 combination.)
The sensitivity difference is much less important than you might think, a G12H-30 and Greenback sound exactly the same volume in a cab, as do the two different Creambacks - it's because the apparently quieter one is more midrangy. The H30 with a G12M-65 would probably sound fine too.
For an amp of only 20W for more of a classic rock rather than hard rock sound, I'd go for the H30/Greenback no question.
In my opinion...
Sounds great to me - BUT, id be interested if @ICBM feels the G12H65 would go better with the 75 - and what the downside of the V30 is with my cur@
FWIW Im powering it with a Fryette Power station - so up to 50w.
The G12M-65 and G12H-75 together is something special though...
A V30 as well you think?
I would go for something looser-sounding and with less mid and more bottom and top - like a Classic Lead 80, G12K-100, or Creamback H75.
* WGS ET-65
* WGS Reaper HP
8 ohms each, wired in series.
JM build | Pedalboard plans
