I've got our other guitar players Vox AD30VT here to play with. It developed a fault and the shop he took it to gave up on trying to fix it.
It randomly turns the effects on or off - takes the amp in or out of bypass. Can happen at any time, every couple of minutes or less frequently.
Just wondered if that's a known fault? If not I suspect it'll be a bitch to find!
The footswitch doesn't operate it, so it won't be the footswitch jack. (It does Ch1/Ch2 with a latching switch on the tip connection, and Manual with a momentary on the ring, which is a stupid design!)
I suspected as much. The bypass button feels ok, could be a dry joint or cracked track around it I suppose, I haven't opened it up yet.
Why would you mix momentary and latching, two different methods, on the same jack for performing the same function? Weirdness!
They're not the only ones - Marshall did it on the Vintage Modern as well, but I'm pretty sure the two footswitches were the other way round... it's stupid either way.
