There is a difference between fret buzz and string rattle - If the note doesn't work due to actual fret buzz, for what ever reason is causing that, then it needs attention - String rattle is effectively physical exertion on the string and the string can no longer oscillate freely - Some players pick harder than others, some stroke the string, so the same guitar with the same action might or might not rattle subject to who is playing it
To acquire a slick easy 'girly' action then I will personally tolerate a hint of string rattle, but I pick very lightly
How much gain you use might come into play as it can 'hide' any string rattle
Generally most acoustic players will tolerate no rattle - However I'm led to believe that the likes of Tony Emmanuel use ultra light action + strings and it rattles like hell, but they need this slick action to allow them to play the way they do
I find that if it's too low it starts to affect the tone and sustain before it's clearly audible as buzzing.
I also only measure for reference, not when setting up. I set up to the minimum action that doesn't buzz or choke when bending, regardless of the measured height. The relief makes quite a difference to the measured action as well, and some necks just need more relief than others, even when the frets are levelled correctly - I'm not totally sure why, but I think the overall resonance of the particular neck comes into it.
My "standard" set up is the same - 2/32" under the high E at the 12th, 3/32" under the low E (sometimes a little lower, sometimes a little higher) - and by and large people are very happy with their guitars.
Sometimes actions can look higher than they are. My PRS DGT has very high frets - which gives the illusion of an action which is higher than it actually is. When measured from the top of the 12th fret, it’s about 1.4mm on the treble side and 1.6mm on the bottom E - which is pretty low.
