True isolated power supply on a budget?
lincolnbluelincolnblue Frets: 294
I know a lot os talked about with regards to power supply and the need for true isolated outputs. Lots of these units are over £100 which is not affordable to many. There are a lot of units which boast true isolation but in reality aren't.
What is the cheapest true isolated power supply?
  • vasselmeyervasselmeyer Frets: 3675
    The answer to this question, as long as you don't need more than 150mA per output, is almost always the Harley Benton Powerplant Jnr which gives you 5x150mA isolated outputs for about £35 from Thomann. Make sure you get the Jnr which is isolated whereas the bigger version actually isn't.
  • DopesickDopesick Frets: 1510
    It's actually 5x120mA but yes still an absolutely ludicrous bit of kit for the money. I've had mine for three years and it has been absolutely fantastic.
  • What about a unit with more outputs?
  • John_AJohn_A Frets: 3775
    edited August 2018
    The one I linked to has a 500 and a 300ma output, you can daisy chain a few pedals from one of those, most analogue pedals don't draw a lot of current and are happy running on a daisy chain.
    If you need more outputs, buy two of them, that way if one fails you can still finish a gig
    If you link your dirt pedals with a daisychain (because they draw virtually nothing and don't interfere with each other,) you can keep the hungrier pedals or the ones that might generate noise to their own outlets. I even ran a Zoom G3 off one using two outlets to make a current doubler. It never even broke a sweat. Here's (quite an old) pedal board I ran it from:
  • SlimbertSlimbert Frets: 341
    The Harley Benton PowerPlant Jr is ridiculous value for money.
    If my board wasn't so power hungry that's probably all I would use. Sadly, having 18v pedals, and some needing upwaeds of 250ma, I've had to buy some bigger power supplies but the PowerPlant Jr really is great for the price tag.
    Even though it's currently hooked up to nothing at all, since it's so cheap, I still have one under my board as a just-in-case unit!
  • poopotpoopot Frets: 9099
    this:
    https://www.musicstore.de/en_GB/GBP/Fame-DCT-200-Multi-Power-Supply-/art-GIT0019066-000
    not the smallest but it works faultlessly and is truly isolated outputs. Been powering my board for years with it.
    That Fame supply really is very good. It's bloody huge though.
  • Has anyone used the Gig Rig stuff?
    Guitars : Fender American Original 60s Stratocaster, Fender Standard Telecaster, Eastman T386 (335 style), Squier Classic Vibe 60s Stratocaster, PRS Bernie Marsden, Eastman AC322CE (acoustic)
    Amps: Tweed Fender Blues Junior, Marshall Origin 20C
    Pedals: Too many to list
    I have a Gigrig system on my big board. The title of the thread contains the word "budget". Those two words don't often go together unless you say "I have a large budget. I think I'll spend it all, and some more, on a Gigrig power system".
    It is fabulous though.
  • normula1normula1 Frets: 640
    I bought one of the Vitoos ISO4plus supplies on the last fleabay offer so paid around £25 or so. It seems OK with "normal" pedals but my PocketPod was unusable due to digital noise.
    I wish I hadn't bothered now.
  • english_bobenglish_bob Frets: 5194
    Come on. If you're deep enough in to guitar to need something like this, you've sunk way more money than that in to your rig. Just about any guitar or amp worth playing is going to be twice that, and most decent pedals are at least as much.
    Sure, a good isolated PSU won't be the most exciting £100 you ever spent on guitar gear, but can you really call £100 "unaffordable"?
    From what I've seen so far, the budget end of the PSU market is some seriously murky water in terms of what's promised vs what's actually the case. Isn't it wiser just to bite the bullet and spend the money *once* on something good?
