Hi guys, I hope I've put this in the right place!
I have a Mexican standard Strat and for a while now my strings keep breaking/uncoiling at the bridge. It happened in soundcheck before my bands
first gig which obviously did wonders for my pre-gig nerves.
The last one to break was my D string (new set of strings) but it's happened to several others before. Obviously it's extremely frustrating but I think I've found the problem and need advice on how to fix it. If it makes any difference I use 11 - 49 D'addario strings.
Here are two pictures, one taken with flash and one without. I think those grooves/dents are called burrs right? I have no idea how to go about fixing them and am really looking for an idiots guide on how to do so.
Apologies for the out of focus pictures.
![image](http://i58.tinypic.com/3166842.jpg)
![image](http://i57.tinypic.com/2hegj12.jpg)
The fact there are burrs in pretty much all of the holes makes me think I should just buy a new bridge. I'm not doing great financially at the moment so would prefer the cheapest solution.
Lastly I just want to say I'm new to this forum and in the couple of weeks I have been here I have gained so much knowledge, so thanks!
Just smooth the edges using a round file and you should be fine.
Thanks a lot mate.
https://soundcloud.com/underwingband
If it was mine, I'd probably just get in there with a round needle file and remove any sharp edges where the string contacts.
In fact, I did exactly this a while ago on a cheap £25 guitar I picked up and refurbished. I finished off the polishing with a bit of fine wet/dry abrasive paper wrapped around the file. Worked fine.
(sweet guitar too!)
Just do the job properly and take them off! It's less than a minute's work. Why bodge when you can do it right more easily?!
Old pic for comparison
