Fantastic MIDI and Pedalboard looper/controller.
In excellent condition, a great brain for any guitar rig.
I've used it as a pedalboard 'looper,' MIDI controller and amp channel switcher all simulataneously and it has performed flawlessly.
It also has six 9v outputs for powering the pedals too, eliminating the need for a dedicated power unit.
Any questions give me a shout.
£260
No original box.
OFFICIAL INFO
graphic LCD TFT display 4,3” with sharp, high quality image
1000x preset (100 banks with 10 presets each)
expression pedal input
6x loop for effect switching
6x relay for amp switching (3 isolated stereo outs)
6x 9V DC output for powering stompboxes (two sections 2x500mA)
switchable high impedance input buffer (identical with a tube amp characteristics) at any preset
dedicated TUNER output with the silent tuning function which receives the signal through very high impedance circuit (no influence on a guitar signal)
LOOP SPLIT mode enabling the connection of two stompboxes at the front and three in the amp fx loop without hums caused by ground loops
phantom power mode for powering the GSC-4 thru midi out connector
midi out and midi in connectors for controlling 10 midi devices independently on different midi channel
adjusting 20 different Midi Control Change numbers for each midi device (10 devices)
12x footswitch (10x multifunction + 2x bank(preset) UP/DOWN)
footswitch modyficator function allows to set the footswitch as: ON/OFF effect or switch amp channel or call the preset on the particular MIDI device
the input for connecting a Wah-Pad WP and Whammy-Pad WP-2,
USB connectors for connecting the keyboard and the computer
intuitive navigation keyboard for direct quick setting
durable, powder-coated casing
Dimensions (width x depth x height): 50cm x 14cm x 6,5cm / 19.7” x 5.5” x 2.6”
Weight: 1,9 kg / 4,2 lbs
Power consumption without 9V outs loading: 24V DC 240mA
____________________
www.adamironside.com
www.youtube.com/Adji87
