Having a bigger load than expected should be fine, you'll just have less power than if you used the right load.
Using a lower impedance is where you risk damage as the amp tries to deliver more power than it is designed for.
Amp is an Epi VJ
Cab is the Epi 1x12 with a 16ohm speaker
