I have replaced the bridge pick in my Keefcaster to a Bare Knuckle Boss and now the middle position is out of phase (white is hot with BKP right?) and I plan to replace the PAF type pickup in the neck to an Oil City humbucker-sized P90 because the PAF is just too muddy with the current pots. The thing is, the P90 has three wires (bare, red, black) and it has flummoxed me. To complicate matters, I have a push pull pot that originally split the neck humbucker.
How can I wire up the Boss and the P90 so that I don't have the out of phase in the middle position and what could I use the push pull for? Maybe both on in series?
Merci!
What can you use the push-pull for? A phase switch of course! Or series if you prefer, but if you found a neck humbucker too muddy then you will find a Tele bridge pickup and a P90 in series even more so, I think.
On my HB Mighty 90/Jazz 90/Smooth 90 you simply reverse the black and white wires to reverse the electrical phase ... the bare wire always goes to ground (it's connected to the pickup baseplate internally).
One other thought. Was the pickup purchased brand new or pre-owned?
You can't tell without a means of checking the magnetic polarity or examining the coil connections. If you have two pickups you can tell if they're the same polarity or opposite by holding them face-to-face and seeing if the attract or repel - although that will only help with those two pickups, you still don't know the real polarity - for that you need to use a small compass.
Use the red and black conductors of the IronGear pickup to correct any phase/polarity issues.
Begin with red as "hot". Keep the bare and black separate just in case the red and black conductors need to be reversed.
The push-pull pot could be used to interconnect both pickups in series but I am not sure that the result would sound especially pleasant.
Other possible uses include;
