FS: Bright Onion Looper with Channel Select & Stereo Channel Select Footswitches.
The looper is basically the same as the current V2 version but without the polarity switch and it has a stereo channel select rather than the V2's mono.
The latching stereo channel select is exactly what it says on the tin. It's worked with every amp I've tried it with so far including Carlsbro, Peavey, Marshall and Laney. It's fully passive apart from the LEDs which run from a 9v battery.
Both pedals have the usual great Bright Onion build quality. I currently only use single channel amps or a single channel of multi channel amps so these are both surplus.
Prices are £30 for the looper and £20 for the stereo channel select. Postage is at cost and
