Is it both the amp and speaker that are 16-ohm, or does the amp have an 8-ohm setting too? If so, use the amp at 8 ohms into the L-Pad and then into the speaker, that's definitely OK. The amp sees the attenuator as the load not the speaker, unless the attenuator is nearly bypassed.
