Hi all,
I have been using Beer bottle washers as strap locks on my LP Goldtop for a while now but as I am upgrading all the hardware I'd like to install something more permanent. I have some Schallers that I could use but I can't use the original screws as the heads are wider than the strap lock holes. I am worried that using the supplied screws that came with the Schallers will chew up the threads in the guitar, is that a problem or am I worrying about nothing? If it is a problem are there any strap locks that allow the use of the original screws please? This may be a stupid question but I have to ask! Thank you for your help.
Tomorrow will be a good day.
I would use the straplock screws, and if they're a bit thinner than the originals - the rear one on a Les Paul will be - pack the holes with glue and toothpicks first so the screw is really tight.
There's nothing more pointless than a strap secured really well to a straplock and a screw, with the rest of the guitar on the floor...
I had strap locks on my LP for a while, but the original rear screw was much fatter than the strap lock screw, so inevitably over time the rear button starts to work loose. At the time I was ignorant of the toothpick/glue thing, so I just switched back to the original screws and buttons, and started using the D'Addario/Planet Waves locking straps where the lock is built into the strap end.
Limits your choice of strap somewhat but they work fine, and aren't too fugly.
They've never loosened in six years of being thrown around at gigs, partly because the design itself means that your strap pivots easily on the button, rather than gripping the button and potentially unscrewing it like other methods.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
http://www.mojoaxe.com/
Ive used it on my es335 which had the same problem at the bottom strap button. The original screw on the back was small enough for a Schaller button. More elegant than glue and toothpicks IMO.
That said, I’ve also used the long/thinner Schaller screw in the bottom button of my R8 and it’s been fine. 4 years and counting.
I do this whenever I fit strap buttons - locks or otherwise - if there’s the slightest doubt about being able to tighten the screw up as far as you can by hand. Not everyone bothers to check the buttons are tight regularly... I find loose ones on a lot of guitars I work on.
Don't use superglue - firstly it will probably set before you put the screw in, which will defeat the compression which makes the thread really strong, and secondly if it doesn't it will bond the screw to the guitar, so you won't be able to get it out again if you ever need to... or not without doing something drastic like heating it. And third, if any gets on the finish you'll make a nasty mess of it.
