I've a 2016 Gibson Les Paul Studio Faded - which i believe is equipped with Burstbuckers.
Recently I've felt it's sounded rather weak and brittle. When compared to my Vintage V100 it sounds thin and weedy like it's not giving full output.
I gigged it on saturday and ended up changing over to a strat which sounded much fatter and more powerful - not what I should be thinking when comparing these two guitars.
Everything on the les paul seems to be working well otherwise - does anyone have any suggestions as to what this could be?
Thanks in advance
Does it affect both pickups? If so it can only be the switch, jack or the connection between them. If it’s one with the PCB in the control cavity I would suspect one of the jumper connectors or a solder joint on the board.
I've remembered i've had another issue whereby when i plugged it in it wouldn't make any sound and i had to toggle the selector switch a few times to make it work - awesome quality on a 2 year old USA built guitar there.........
If it's not that and it does have the PCB, it could a microscopic bad connection that the vibration from flipping the switch would 'cure' - sometimes these things can be amazingly sensitive. If it's a fault on the PCB, probably the easiest and best solution is just to remove the whole thing and fit a traditional loom - the PCB is a solution looking for a problem, or more accurately a problem looking for a problem.
I've literally no idea why gibson fit the PCB boards in the guitars it really is madness
Or not soldering each guitar. I had an ES339 where the wires were wrapped around the lugs of one of the volume pots but not soldered. After a few months, it started cutting out intermittently until the problem was diagnosed.
Gibson pickup selector switches can be a bit of a problem. I had to replace the one on my ES Les Paul when it was only a few months old.
