Looks fine - 3 pc mahogany neck
I'm never a big fan of the frets from that era - wide and low - As such find many play better with a good refret
How much are they asking for it
Overall it looks okay
On pics alone I'm not so sure about a refin - That 'bright' cherry sunburst they used then is fairly distinctive - Some say tomato soup burst
many are heavy around this era
It is not a bargain at £2500 but at that price I'd want all original
The finish is much nicer than the usual 'clownburst' Gibson were doing then. I like the wide low frets too. It's a good weight, the price is about right - if you can get a couple of hundred off then it's probably as good as you'll easily find one of that era.
I could easily see them doing it on some LP Deluxes as well.
valid point on the brown control plates, but sure I've seen black in the past ! - faded memory time and chances are either transition issues and/or using other parts if low/no stock - Both happen
I've only ever seen black plates on Customs (of all colours) in the 70s, or the Pro Deluxe in black.
The screws are also the wrong size, although that doesn't necessarily mean the plates have been replaced.
