The next day I fired up the AX8 at home to see if I could figure out the problem. I noticed it straight away. I had the enhancer block in a parallel path with some weird settings. (I must have moved this at some point because I'm sure I had it in series originally).
I seemed to remember reading on the Fractal forum that this isn't recommended as it can create phase issues, which in hindsight was exactly what I was experiencing. I moved the enhancer block so it was back in series, I adjusted the settings and it sorted the problem out. All the punch came back.
