First of all, scoping the preamp (between first gain stage and second, where the volume and tone controls are) I got a perfect sine wave at all volumes, though the trace did keep jumping vertically up and down the screen as I adjusted the volume. Does this indicate a grounding issue, or nothing at all?
Second, the phase inverter shows significant clipping (see first picture below, where volume was set at 5) which I think is normal isn't it? If I turn the volume down to as low as it will go, one side distorts before the other (see the second picture below). Could this be my problem?
From the way the volume pot is being scratchy, I think it's probably a problem with the earlier part of the circuit, either grounding or maybe some swarf/wire trimmings/solder has got into the pot (I've replaced the bright channels first coupling cap and this made no difference, so I don't think there's DC on the pots).
What do you people think?
(And whatever the problem is, oscilloscopes are really good fun.)
